Bug 2278 - TTeeGrid.ReadOnly property does not work in design mode
Summary: TTeeGrid.ReadOnly property does not work in design mode
Product: TeeGrid for Delphi
Assignee: david berneda
Reported: 2020-01-16 23:16 EST by dean.mustakinov
Modified: 2020-01-24 05:01 EST (History)
Description dean.mustakinov 2020-01-16 23:16:59 EST
Setting TTeeGrid.ReadOnly to True in the form designer does not work.
TTeeGrid.ReadOnly property has "default True" option set so when form is saved "True" value for ReadOnly property will not be saved.
Underlying TTeeGrid code does not set ReadOnly property to True when TTeeGrid is created so grid is not read only and data can be edited.
Changing TTeeGrid.ReadOnly property default option to "False" allows saving of ReadOnly = True in the form and everything works as expected.
Comment 1 marc meumann 2020-01-24 05:01:04 EST
Thanks for the feedback Dean. Change made for next update.
