Bug 2204 - Give access to the Series StartZ and EndZ properties
Summary: Give access to the Series StartZ and EndZ properties
Version: TeeChart Pro Activex Control 2018.0.2.9 Release
Reported: 2019-05-23 07:32 EDT by yeray alonso
Modified: 2020-04-06 12:45 EDT (History)
Description yeray alonso 2019-05-23 07:32:18 EDT
In VCL you can set StartZ and EndZ properties.
These properties are set at the beginning of the drawing routine, but they make effect if you set them at the OnBeforeDrawAxes event.
This would allow to use the Shape series manually setting its Z position.
It would be easier if we had a 3D Shape series as requested in the following ticket, which also includes a Delphi example using the StartZ and EndZ at OnBeforeDrawAxes event as a workaround:
http://bugs.teechart.net/show_bug.cgi?id=2203
Comment 1 pep jorge 2020-04-06 12:45:18 EDT
StartZ,MiddleZ, and EndZ properties added for v2020.
Now you're able to do :
Private Sub Form_Load()
Dim i As Integer
  TChart1.Aspect.Chart3DPercent = 70
  TChart1.Aspect.Zoom = 70
  TChart1.Aspect.Orthogonal = False
  TChart1.Axis.Depth.Visible = True
  TChart1.Axis.Depth.Labels.Style = talValue
  TChart1.Axis.Depth.SetMinMax 0, 5
  TChart1.Axis.Left.SetMinMax 0, 5
  TChart1.Axis.Bottom.SetMinMax 0, 5
  TChart1.Axis.Depth.Increment = 1
  TChart1.Axis.Left.Increment = 1
  TChart1.Axis.Bottom.Increment = 1
  For i = 0 To 5
    TChart1.AddSeries scShape
    With TChart1.Series(i).asShape
        .X0 = i
        .X1 = i + 1
        .Y0 = i
        .Y1 = i + 1
        .Style = chasCube
    End With
  Next i
Private Sub TChart1_OnBeforeDrawAxes()
Dim i As Integer
  For i = 0 To TChart1.SeriesCount - 1
         If TChart1.Series(0).YMandatory Then
            .StartZ = TChart1.Axis.Depth.CalcYPosValue(i)
            .EndZ = TChart1.Axis.Depth.CalcYPosValue(i + 1)
            .Depth = TChart1.Axis.Depth.CalcYPosValue(1) - TChart1.Axis.Depth.CalcYPosValue(0)
        End If
    End With
    Next i
