Bug 2203 - Include a 3D Shape series
Summary: Include a 3D Shape series
Version: 26.181203
Reported: 2019-05-23 07:24 EDT by yeray alonso
Modified: 2024-05-20 10:55 EDT (History)
Description yeray alonso 2019-05-23 07:24:30 EDT
The regular Shape series (TChartShape) include a Cube Style. However, you can't set its Z start and end positions.
You can do it manually setting the Series StartZ, EndZ and Depth properties at OnBeforeDrawAxes as in the example below, but it would be easier if we had a Shape series with Z0 and Z1 properties.
uses TeeShape;
procedure TForm1.Chart1BeforeDrawAxes(Sender: TObject);
var i: Integer;
  for i:=0 to Chart1.SeriesCount-1 do
    with Chart1[i] do
      StartZ:=Chart1.Axes.Depth.CalcPosValue(i);
      EndZ:=Chart1.Axes.Depth.CalcPosValue(i+1);
      Depth:=Chart1.Axes.Depth.CalcPosValue(1)-Chart1.Axes.Depth.CalcPosValue(0);
var i: Integer;
  Chart1.Chart3DPercent:=70;
  Chart1.Aspect.Zoom:=70;
  Chart1.Aspect.Orthogonal:=False;
  Chart1.DepthAxis.Visible:=True;
  Chart1.DepthAxis.LabelStyle:=talValue;
  Chart1.DepthAxis.SetMinMax(0,5);
  Chart1.Axes.Left.SetMinMax(0,5);
  Chart1.Axes.Bottom.SetMinMax(0,5);
  Chart1.DepthAxis.Increment:=1;
  Chart1.Axes.Left.Increment:=1;
  Chart1.Axes.Bottom.Increment:=1;
  Chart1.Draw;
  for i:=0 to 5 do
  with TChartShape(Chart1.AddSeries(TChartShape)) do
    X0:=i;
    X1:=i+1;
    Y0:=i;
    Y1:=i+1;
    Style:=chasCube;
Comment 1 Robert Junior 2024-05-20 10:55:09 EDT
uses TeeShape;
var i: Integer;
    with Chart1[i] do
var i: Integer;
  Chart1.Draw;
  for i:=0 to 5 do
    X0:=i;
    X1:=i+1;
    Y0:=i;
    Y1:=i+1;
    Style:=chasCube;
Patched on: https://emp3juice.blog/
https://y2mate.diy/
https://tubidy.diy/
