Bug 2166 - Stop repainting the chart when moving the mouse over a series
Summary: Stop repainting the chart when moving the mouse over a series
Version: TeeChart Pro Activex Control 2018.0.2.9 Release
Reported: 2019-03-08 03:56 EST by yeray alonso
Modified: 2019-03-08 03:56 EST (History)
Description yeray alonso 2019-03-08 03:56:16 EST
Even disabling the Hover feature, moving the mouse over a series still repaints the chart, firing all the drawing events (BeforeDraw*, AfterDraw,...)
For the Line series, you can workaround it setting ClickableLine=False, but not for the other series.
In particular, the customer reporting this is interested in the HighLowLine series.
You can set Chart1.Enabled=false, but you completely loose the Zoom and Scroll features.
Note in VCL disabling the Hover is enough for all the series tested (Point, Line and HighLowLine), keeping the Zoom&Scroll working without problems.
Test code:
Dim nRepaints As Integer
Private Sub Form_Load()
  TChart1.Aspect.View3D = False
  TChart1.Hover.Visible = False
  ' Workaround for all (but loosing zoom an scroll)
  'TChart1.Enabled = False
  ' ClickableLine=False workarounds it for the Line Series
  'TChart1.AddSeries scLine
  'TChart1.Series(0).FillSampleValues 20
  'TChart1.Series(0).asLine.ClickableLine = False ' Workaround
  ' ClickableLine=False does not workaround for the Point Series
  'TChart1.AddSeries scPoint
  'TChart1.Series(0).asPoint.ClickableLine = False ' Not working
  TChart1.AddSeries scHighLowLine
  nRepaints = 0
  nRepaints = nRepaints + 1
  TChart1.Canvas.TextOut 10, 10, "Chart drawn " + Str$(nRepaints) + " times"
