Bug 2099 - TeeProcs checks for cond. define FASTMM but if set, does not compile
Summary: TeeProcs checks for cond. define FASTMM but if set, does not compile
Reported: 2018-09-27 10:58 EDT by Thomas Mueller
Modified: 2023-03-17 08:39 EDT (History)
Delphi / C++ Builder RAD IDE Version: RAD 2007
Description Thomas Mueller 2018-09-27 10:58:44 EDT
Unit TeeProcs, line 8170 (class function TTeeCPU.TotalMemoryAllocated) contains the following code:
  result:={$IFDEF D16}
            {$IFDEF MSWINDOWS}
            MemoryUsed;
            {$ELSE}
            0  // Posix, MACos, iOS, Android
            {$ENDIF}
          {$ELSE}
            {$IFDEF FASTMM}
            FastGetHeapStatus
            {$ELSE}
            GetHeapStatus
            {$ENDIF}.TotalAllocated;
          {$ENDIF}
(formatting changed)
If the conditional define FASTMM is set, it tries to call FastGetHeapStatus which is not available because the Unit that supposedly provides it is not in the uses list.
If not set, it calls GetHeapStatus which (at least in Delphi 2007) is marked as deprecated. The Delphi online help states:
"Note: Since GetHeapStatus is deprecated, use GetMemoryManagerState routine instead."
