Bug 2095 - The RemoveGrap property doesn’t work when is using MaxPointsPerPage property or Axes SetMinMax method
Summary: The RemoveGrap property doesn’t work when is using MaxPointsPerPage property...
Status: RESOLVED WONTFIX
Reported: 2018-09-26 08:13 EDT by sandra pazos
Modified: 2018-11-13 07:55 EST (History)
Simple project example (10.51 KB, application/x-zip-compressed)
2018-09-26 08:13 EDT, sandra pazos
RemoveGaps project (14.99 KB, application/x-zip-compressed)
2018-11-09 07:14 EST, sandra pazos
Description sandra pazos 2018-09-26 08:13:03 EDT
Created attachment 858 [details]
The RemoveGrap property doesn’t work when is using MaxPointsPerPage  property or Axes SetMinMax method. The attached application reproduces the problem. The problem doesn’t occur if you set to false the RemoveGap property.
Comment 1 sandra pazos 2018-11-09 07:14:52 EST
Created attachment 869 [details]
RemoveGaps project
Comment 2 christopher ireland 2018-11-13 07:55:17 EST
If the Candle series' MaxXValue() and MinXValue() are not called then the RemoveGap code will not work - this happens when the Automatic property of the bottom axis is false, as when the SetMinMax method is called, or when the Paging code is invoked.
