Bug 2088 - Switching from a large maximum to a small maximum for an axis can result in an Range Check Error
Summary: Switching from a large maximum to a small maximum for an axis can result in a...
Status: UNCONFIRMED
Reported: 2018-09-17 09:14 EDT by Thomas Mueller
Modified: 2018-09-17 09:14 EDT (History)
Description Thomas Mueller 2018-09-17 09:14:18 EDT
Create a chart with one series that has at least one very large Y-Value (>100 Million)
Set LeftAxis scaling to Automatic.
Add a Cursor Tool
Add code to remove the above series and add one with small Y-Values (0<y<1).
You will get a RangeCheckError here:
Function TChartAxis.YPosValueCheck(Const Value:TChartValue):Integer;
var tmp : TAxisValue;
  if IRangeZero then result:=ICenterPos
    tmp:=(Value-IMinimum)*IAxisSizeRange;
    if IUseTeeMaxPixelPos then
      if FInverted then tmp:=IStartPos+tmp
                   else tmp:=IEndPos-tmp;
      if tmp> TeeMaxPixelPos then
        result:= TeeMaxPixelPos
      if tmp<-TeeMaxPixelPos then
        result:=-TeeMaxPixelPos
         result:=Round(tmp);
    end
    if FInverted then result:=IStartPos+Round(tmp) // <== here
                 else result:=IEndPos-Round(tmp);  // <== or here
That's because tmp becomes much larger than MaxInt.
This does not happen if IUseTeeMaxPixelPos is true (but there is no way to do that without subclassing TAxis). Or if Chart1.Axes.FastCalc is true (which calls  the method YPosValue instead of YPosValueCheck).
