Bug 2068 - Access violation after loading a chart
Summary: Access violation after loading a chart
Status: RESOLVED DUPLICATE of bug 2067
Reported: 2018-08-03 08:39 EDT by info@redusoft.de
Modified: 2018-09-10 11:12 EDT (History)
Executable file with source code (Delphi 7), which demonstrates the access violation (1.07 MB, application/zip)
2018-08-03 08:39 EDT, info@redusoft.de
Description info@redusoft.de 2018-08-03 08:39:53 EDT
Created attachment 842 [details]
Dear Sirs,
an access violation appears if a loaded Chart must be edited.
By a click on Button 'Save' (Button1) Chart1 is saved.
After a click on Button 'Load' (Button2) the Chart1 will be loaded.
This works.
But if the loaded Chart1 thereupon will be edited (by a click on Button 'EditSeries' (Button3) an
access violation appears. Could you please give me an answer what's wrong there ?
Only the following code is implemented:
 SaveChartToFile( TCustomChart( Chart1 ), 'd:\mychart1.tee',true,true);
 LoadChartFromFile( TCustomChart( Chart1 ), 'd:\mychart1.tee');
procedure TForm1.Button3Click(Sender: TObject);
 EditSeries(Self,Series1); // -> results in an access violation if a
                           // saved chart is loaded.
In attachmaent you can find the exe file and the source code of the
application which doesn't work correctly. Please start the file project1.exe and click on Button
'Save' to save the chart. Then click on Button 'Load' to load the chart. After a click on Button
'EditSeries' the error (access violation) occurs.
Best regards
Ralf Riescher
Comment 1 sandra pazos 2018-09-10 11:12:30 EDT
*** This bug has been marked as a duplicate of bug 2067 ***
