Bug 2067 - Access violation after loading a chart
Summary: Access violation after loading a chart
: 2068 (view as bug list)
Reported: 2018-08-03 08:32 EDT by info@redusoft.de
Modified: 2023-03-15 15:45 EDT (History)
Executable file with source code (Delphi 7), which demonstrates the access violation (1.07 MB, application/zip)
2018-08-03 08:32 EDT, info@redusoft.de
Description info@redusoft.de 2018-08-03 08:32:43 EDT
Created attachment 841 [details]
Dear Sirs,
an access violation appears if a loaded Chart must be edited.
By a click on Button 'Save' (Button1) Chart1 is saved.
After a click on Button 'Load' (Button2) the Chart1 will be loaded.
This works.
But if the loaded Chart1 thereupon will be edited (by a click on Button 'EditSeries' (Button3) an access violation appears. Could you please give me an answer what's wrong there ?
Only the following code is implemented:
 SaveChartToFile( TCustomChart( Chart1 ), 'd:\mychart1.tee',true,true);
 LoadChartFromFile( TCustomChart( Chart1 ), 'd:\mychart1.tee');
procedure TForm1.Button3Click(Sender: TObject);
 EditSeries(Self,Series1); // -> results in an access violation if a
                           // saved chart is loaded.
In attachmaent you can find the exe file and the source code of the
application which doesn't work correctly. Please start the file project1.exe and click on Button 'Save' to save the chart. Then click on Button 'Load' to load the chart. After a click on Button 'EditSeries' the error (access violation) occurs.
Best regards
Ralf Riescher
Comment 1 sandra pazos 2018-09-10 11:11:19 EDT
We find a workaround to fix the problem you experiencing. Basically, you need use Chart[0] instead of Series1.
The code below shows how can do it:
 EditSeries(Self,Chart1[0]);
Comment 2 sandra pazos 2018-09-10 11:12:30 EDT
*** Bug 2068 has been marked as a duplicate of this bug. ***
Comment 3 david berneda 2023-03-15 15:45:19 EDT
When loading a chart, the series contained in it are not automatically assigned to variables in the form.
So, Series1 is not assigned to Chart1.Series[0] when loading it back.
Delphi maintains the Series1 variable when loading the DFM form for the first time, but not for later save/load.
The workaround is, after loading the form, to manually reset the variable:
 LoadChartFromFile( TCustomChart( Chart1 ), 'c:\mychart1.tee');
 Series1 := Chart1[0];   // <---
