Bug 2035 - Painting artefacts when some values = 0 between non-zero values in pie chart in ReportBuilder
Summary: Painting artefacts when some values = 0 between non-zero values in pie chart ...
Version: 24.180321
Reported: 2018-05-14 04:58 EDT by Toni Grabmayr
Modified: 2018-05-25 07:18 EDT (History)
Screenshot, RB-RTM-file (9.14 KB, application/x-zip-compressed)
2018-05-14 05:00 EDT, Toni Grabmayr
GDI+ Configuration in RB designer (96.23 KB, image/jpeg)
2018-05-23 09:58 EDT, Toni Grabmayr
Description Toni Grabmayr 2018-05-14 04:58:58 EDT
Hi
Please see attached screen shot and RB-RTM-file. Whenever there's a zero-value between non-zero-values there are painting artefacts with a line painted outside the graph.
regards
Toni
Comment 1 Toni Grabmayr 2018-05-14 05:00:16 EDT
Created attachment 829 [details]
Comment 2 yeray alonso 2018-05-23 06:58:44 EDT
I can reproduce the problem with this simple example:
uses Series, TeCanvas;
  with Chart1 do
    View3D := False;
    Canvas := TTeeCanvas3D.Create;
    with Chart1.AddSeries(TPieSeries) as TPieSeries do
      AddPie(0);
      AddPie(9);
      AddPie(0);
      AddPie(0);
      AddPie(1);
Note this is reproducible in GDI, but works fine in GDIPlus. Try changing the DefaultCanvas property in your .rtm as follows:
DefaultCanvas = 'TGDIPlusCanvas'
Comment 3 Toni Grabmayr 2018-05-23 09:56:29 EDT
Hi
I tried to set this via RB's designer. However, the GDI+ option in tab "Render" can be set but this value seems not to be stored as always when I re-enter the original values remain (GDI).
Have I got to extend the underlying uses clause to be able to set this? Which units should there be?
Regards
Toni
Comment 4 Toni Grabmayr 2018-05-23 09:58:10 EDT
Created attachment 831 [details]
Comment 5 yeray alonso 2018-05-23 10:16:19 EDT
TGDIPlusCanvas is defined in TeeGDIPlus unit. Try adding it to the uses clause.
Other alternatives I see here:
- Contact Digital Metaphors to check if they are forcing GDI in the charts in their reports and, in that case, check if there's a way to activate GDIPlus.
- Generate an image from a hidden (or without parent) TChart and use that image in  the report.
Comment 6 Toni Grabmayr 2018-05-24 04:21:47 EDT
I added TeeGDIPlus to the uses. This results in bringing other options when I choose GDI+ in the chart's configuration. However, this setting is not taken over when clicking "close"-button.
The concerning report is designed withen RB's designer at runtime using your (additional) component to design/configure the chart. Beside TeeGDIPlus which units have to be added to the uses clause to achive at least a saving of the chosen options?
Further when I try to change an option within GDI+ settings I run into an Exception what indicates that either this all doesn't work at all or there are missing units. Please advise which additional units have to be in my uses clause.
If this all is not achievable isn't it possible for you to fix the problem with the 0-lines in GDI as well?
Regards
Toni
Comment 7 yeray alonso 2018-05-25 07:18:17 EDT
(In reply to Toni Grabmayr from comment #6)
> uses clause.
Can any of these problems be reproduced without Report Builder? If not, I'd contact Digital Metaphors to see if they can do anything at their side.
With just a Chart on the form, without RB, you can activate GDIPlus by just adding TeeGDIPlus to the uses clause. I'm not sure if there's any other requirement in the integration of TeeChart into RB. Digital Metaphors supports this integration.
I've just fixed for the next maintenance release, so I'll close this ticket.
