Bug 2023 - BiGrid throws an Access violation exception when the columns are moved
Summary: BiGrid throws an Access violation exception when the columns are moved
Product: TeeBI for Delphi
Component: BIGrid (show other bugs)
Assignee: david berneda
Reported: 2018-03-26 08:14 EDT by sandra pazos
Modified: 2018-03-26 08:14 EDT (History)
Description sandra pazos 2018-03-26 08:14:01 EDT
BiGrid throws an Access violation exception when the columns are moved. The problem doesn't appear in TeeGrid, may be interesting adapt BIGrid to TeeGrid to fix this problem
You can reproduce the problem using the TeeBI_Data_Ranks Demo. To do that follow the steps below:
1- Open TeeBI_Data_Ranks Demo and compile it.
2- Run the Demo and Select for example, Year column
3- Try move Year from first postion to last postion.
The access violation appears.
