Bug 1989 - Bottom Axes label & annotation is not working
Summary: Bottom Axes label & annotation is not working
Version: TeeChart for .Net 4.1.2015.12165
: --- blocker
Reported: 2018-02-13 22:49 EST by juliana
Modified: 2018-04-05 11:33 EDT (History)
version compare (65.10 KB, image/png)
2018-02-13 22:50 EST, juliana
Description juliana 2018-02-13 22:49:45 EST
Hi there,
Bottom Axes label & annotation is not working after upgrade to 4.1.2017.10190 from 4.1.2015.12160.
Source code to set bottom axes label:
tChart.Series[i].Add(dValueDays, dValue, label);
Source code to set annotation:
annotation.Text = dr["class_name"].ToString() + Environment.NewLine +
dr["bond_name"].ToString() + Environment.NewLine +
"Remaining Tenure: " + dr["remaining_years"].ToString() + " year(s)" + Environment.NewLine +
"Remaining Tenure (expected maturity): " + dr["exp_remaining_years"].ToString() + Environment.NewLine +
"Eval Mid Price: " + dr["mtm_price"].ToString() + Environment.NewLine +
"Eval Mid Yield/Discount: " + dr["mtm_ytm"].ToString();
Please refer to attachment.
Both codes is working fine in version 4.1.2015.12160.
Comment 1 juliana 2018-02-13 22:50:32 EST
Created attachment 813 [details]
version compare
Comment 2 christopher ireland 2018-02-14 13:14:43 EST
The axis label defect is a regression introduced in version 4.1.2016.10260 in the code change related to http://bugs.teechart.net/show_bug.cgi?id=1606 I can reproduce the issue with the following code:
	Line series = new Line(tChart1.Chart);
	DateTime dt = DateTime.Today;
	int year, oldYear = 0;
	for (int i = 0; i < 10000; i++)
		year = dt.Year;
		string label = year != oldYear ? year.ToString() : "";
		series.Add(dt, Math.Log(i), label);
		dt = dt.AddDays(1);
		oldYear = year;
I have fixed this regression, and in the meantime the workaround is to use repeated labels e.g.
		series.Add(dt, Math.Log(i), dt.Year.ToString());
		dt = dt.AddDays(1);
The annotation defect is a regression introduced in version 4.1.2017.10190 (change for Xamarin.Forms) in code related to http://bugs.teechart.net/show_bug.cgi?id=1874. I can reproduce the issue with the following code:
	Annotation tool = new Annotation(tChart1.Chart);
	tool.Position = AnnotationPositions.Center;
	StringBuilder builder = new StringBuilder();
	for (int i = 1; i < 10; i++)
		builder.Append("This is text line " + i.ToString() + " of a multi-line series" + Environment.NewLine);
	tool.Text = builder.ToString();
We are looking into a fix for this regression, and in the meantime the workaround is to derive from the Annotation tool and override the erroneous method e.g.
public class MyAnnotation : Annotation
	public MyAnnotation(Chart c): base(c) { }
	protected override int CalcTempWidth(Graphics3D g, string tmp, out int numLines)
		int i = tmp.IndexOf(Environment.NewLine);
		int result = 0;
		numLines = 0;
		while (i > 0)
			result = Utils.Round(Math.Max(result, g.TextWidth(tmp.Substring(0, i))));
			++numLines;
			tmp = tmp.Remove(0, i + Environment.NewLine.Length);
		if (tmp != "")
			result = Utils.Round(Math.Max(result, g.TextWidth(tmp)));
			++numLines;
		return result;
to use:
	MyAnnotation tool = new MyAnnotation(tChart1.Chart);
