Bug 1979 - Stack Overflow when calling SaveChartToStream while using PartnerAxis
Summary: Stack Overflow when calling SaveChartToStream while using PartnerAxis
Version: 23.171221
Reported: 2018-01-29 09:08 EST by yeray alonso
Modified: 2023-03-16 07:16 EDT (History)
test project (49.99 KB, application/x-zip-compressed)
2018-01-29 09:08 EST, yeray alonso
Description yeray alonso 2018-01-29 09:08:26 EST
Created attachment 808 [details]
test project
As the customer reports in the forums, having two axes set each to be partner axis for the other, saving the chart to a stream causes a Stack Overflow error.
Also, if you only set one of them, then the chart is saved without errors, but loading the chart from the stream generated (LoadChartFromStream) gives an "Invalid property path" error.
Comment 1 david berneda 2023-03-16 07:16:33 EDT
Fixed both problems.
PartnerAxis property is now streamed as a custom hidden property in the dfm stream (via DefineProperties), as an integer, which is correctly loaded and assigned.
