Bug 1977 - Polar series using a Dataset and ClockWiseLabels breaks the angles
Summary: Polar series using a Dataset and ClockWiseLabels breaks the angles
Version: 23.171221
: 1971 (view as bug list)
Reported: 2018-01-25 06:47 EST by yeray alonso
Modified: 2018-02-23 10:20 EST (History)
Chart Series: Polar
test project (50.04 KB, application/x-zip-compressed)
2018-01-25 06:47 EST, yeray alonso
Description yeray alonso 2018-01-25 06:47:30 EST
Created attachment 806 [details]
test project
See the project attached.
- If you run it as-is (ClockWiseLabels=false at designtime) everything works as expected.
- If you check the ClockWise checkbox (at Series\Format\Labels\Options tab), both the circle labels and the series have rotated (which is correct). Now, when you run, you'll see the series has moved 180 degrees (which is wrong).
As a temporal workaround, you can reload the data making sure ClockWiseLabels=false and set it to true after it:
  Series1.ClockWiseLabels:=False;
  Series1.CheckDataSource;
  Series1.ClockWiseLabels:=True;
Comment 1 sandra pazos 2018-02-23 10:20:10 EST
*** Bug 1971 has been marked as a duplicate of this bug. ***
