Bug 1973 - Can't control chart title
Summary: Can't control chart title
Reported: 2018-01-23 00:48 EST by seoyleenv
Modified: 2023-03-17 08:40 EDT (History)
I deleted the chart title in 'Edit Chart', but it shows the default title 'TeeChart' (199.04 KB, image/jpeg)
2018-01-23 00:48 EST, seoyleenv
Description seoyleenv 2018-01-23 00:48:22 EST
Created attachment 805 [details]
I used VB6 and my problem is...
I deleted a chart title in 'Edit chart', compiled and running. But, chart shows the title as 'TeeChart'. In case, I changed the default title, 'TeeChart', as another one, then it is correctly displayed.
Comment 1 sandra pazos 2018-01-26 09:40:49 EST
I confirm the problem you're experiencing appear for us. The problem doesn't appear if we change the Chart Title by code using line code below:
TChart1.Header.Text.Text = "Chart"
Thanks in advance
Comment 2 sandra pazos 2018-07-27 07:00:46 EDT
The problem is produced in VCL.
Basically, the problem is caused because "Chart.Title.Text" or header text is not persisted.
A  workaround is setting Title.Visible = True
