Bug 196 - [TV52014940] Logarithminc axis doesn't control fine the number of labels to draw w...
Summary: [TV52014940] Logarithminc axis doesn't control fine the number of labels to d...
Reported: 2010-06-07 13:41 EDT by yeray alonso
Modified: 2014-11-03 07:14 EST (History)
Description yeray alonso 2013-11-20 10:03:02 EST
Logarithminc axis doesn't control fine the number of labels to draw without overlapping
Similar and probably related to TV52013473.
uses Series, Math;
var
  Series1: TFastLineSeries;
  x,y: extended;
  i: integer;
  Chart1.Legend.Visible:=false;
  Series1:=Chart1.AddSeries(TFastLineSeries.Create(self)) as TFastLineSeries;
  for i:=1 to 100 do
    x:=0.5*i;
    y:=power(x,i);
    Series1.AddXY(x,y);
  Chart1.Axes.Left.Logarithmic:=true;
  Chart1.Axes.Left.LabelsSeparation:=50;  //això semblava un workaround en alguns casos, però aquí no fas res :-(
//  Chart1.Axes.Left.LogarithmicBase:=1E13;  //workaround
In NET it behaves different. If you try to draw the same values, the left axis labels are too long. So I do:
tChart1.Axes.Left.Labels.ValueFormat = "00e-0";
And the result is quite different than in VCL. [created:2010-06-07T12:41:08.000+01:00 reported by:yeray@steema.com reported in version:9.0 (TeeChart VCL)]
Comment 1 Paul 2014-11-03 07:14:05 EST
The same problem occurs when we try to zoom chart with logarithmic scale.
Before zoom:
http://tinypic.com/view.php?pic=2v1xhcl&s=8
After zoom:
http://tinypic.com/view.php?pic=2uzqwx0&s=8
