Bug 1949 - unwanted Application.HintPause overwrite by TMarksTipTool.MouseDelay
Summary: unwanted Application.HintPause overwrite by TMarksTipTool.MouseDelay
Reported: 2017-11-23 05:02 EST by boris.seve
Modified: 2018-02-26 11:51 EST (History)
Description boris.seve 2017-11-23 05:02:41 EST
Application.HintPause is modified by TMarksTipTool even if SystemHints is set to False.
TFrame > TChart > TMarksTipTool > SystemHints = False
I looked in your sources and my understanding is that in vcl TMarksTipTool.SystemHints is set to True in Create.
your source:
  constructor TMarksTipTool.Create(AOwner: TComponent);
    inherited;
    FSystemHints:={$IFDEF FMX}False{$ELSE}True{$ENDIF};
    FStyle:=smsLabelOrValue;
    FHidePause:=2500;
    FFormat:=TTextShape.Create(nil);
    FFormat.Visible:=False;
    FFormat.TextAlignment:=taCenter;
    FFormat.CustomPosition:=True;
The craft of the dfm set SystemHints after MouseDelay.
dfm extract example:
  object ChartTool1: TMarksTipTool
    Format.CustomPosition = True
    Format.Left = 0
    Format.TextAlignment = taCenter
    Format.Top = 0
    Format.Visible = False
    MouseDelay = 0
    SystemHints = False
  end
So when the dfm is loaded, it set the MouseDelay before SystemHints so it affects Application.HintPause.
your source:
  procedure TMarksTipTool.SetMouseDelay(const Value: Integer);
    {$IFNDEF FMX}
    if SystemHints then
       Application.HintPause:=Value
    {$ENDIF}
       FMouseDelay:=Value;
Thanks guys.
Comment 1 marc meumann 2018-02-26 11:51:27 EST
fix:
Property now delays possible setting of Application.HintPause until component is loaded.
Change can be made in current code this way:
//Modify existing setter:
  {$IFNDEF FMX}
  if (not (csLoading in ComponentState)) and SystemHints then
  {$ENDIF}
     FMouseDelay:=Value;
//new protected method in TMarksTipTool:
procedure TMarksTipTool.Loaded;
Begin
  inherited;
  {$IFNDEF FMX}
  if SystemHints then
     Application.HintPause:= MouseDelay;
  {$ENDIF}
