Bug 1940 - Appears a problem in Excel using the propierties Ranges and Axis Ranges of CircularGauge
Summary: Appears a problem in Excel using the propierties Ranges and Axis Ranges of Ci...
Reported: 2017-11-09 11:53 EST by sandra pazos
Modified: 2018-02-15 18:00 EST (History)
Excel Exemple (14.07 KB, application/x-zip-compressed)
2017-11-09 11:53 EST, sandra pazos
Description sandra pazos 2017-11-09 11:53:25 EST
Created attachment 793 [details]
Excel Exemple
When you try to change or add Ranges or AxisRanges in the CircularGauge, appear the bellow errors:
“Run-time error '-2147417848 (80010108)':
Method 'StartValue' of object 'IGaugeRange' failed”
Method 'EndValue' of object 'IGaugeRange' failed
The attached project, reproduce the problem.
Note to run the problem you should active Developer excel menu and select visual basic option.
