Bug 192 - [TV52014854] I am using the native tee-chart format for that task. Everything work...
Summary: [TV52014854] I am using the native tee-chart format for that task. Everything...
Reported: 2010-05-06 13:08 EDT by narcís calvet
Modified: 2015-04-16 06:42 EDT (History)
Description narcís calvet 2013-11-20 10:02:44 EST
I am using the native tee-chart format for that task. Everything works fine but some properties are overwritten whenever I call the "LoadChartFromFile" function and view the chart in a TChart component. For example the Panel-Gradient property allways is checked and the background of the TChart is gradient even if it was unchecked when saving the file. When I open up a preview with a TChartPreviewer that is connected to the same TChart, the backgound is not gardient. Saving the chart again allways stores the Panel-Gradient property as checked if I do not manually uncheck it before saving.
I attached a project where you can see the problem. You muss do the following:
1. Start the project
2. Uncheck then Panel-Gradient-Visible property in the chart editor
3. Close the chart editor
4. Save the chart to file by clicking the "Save" button
5. Close the application
6. Restart the application
7. Click the "Open" Button and load the file you saved in step 4
Now you should see that the gradient background is still there. If you load the file right after you saved it without closing the app the effect doesn't occur. [created:2010-05-06T12:08:00.000+01:00 reported by:narcis@steema.com reported in version:8.07.70413 (TeeChart VCL)]
