Bug 1918 - teegrid 1.02 source installation on Delphi tokio starter problem
Summary: teegrid 1.02 source installation on Delphi tokio starter problem
Status: RESOLVED WONTFIX
Product: TeeGrid for Delphi
: --- blocker
Assignee: david berneda
Reported: 2017-09-14 04:19 EDT by michel.pedimina
Modified: 2018-02-27 10:29 EST (History)
Description michel.pedimina 2017-09-14 04:19:19 EDT
I acquired TeeGrid and followed the installation procedure on windows Delphi Tokyo 10.2.
Since i am using Delphi starter, the instructions report the following:
1) Run Delphi Starter and Open project ...
2) Do Project --> Build All Projects.
Unfortunately, doing so result in a compilation error and the installation cannot proceed.
The error I have is the following:
[dcc32 Fatal Error] VCLTee.Painter.pas(22): F2613 Unit 'Graphics' not found.
How can that be solved?
To overcome the problem , I tried to install the binary version, here as well installation is apparently successful but I do not see the components in the IDE.
Regards
Mped
Comment 1 sandra pazos 2018-02-27 10:29:36 EST
Hello Michel,
TeeGrid doesn't support Rad Studio Starter versions, so the Rad Studio Starter versions BDE limitations. You can check it from the link below:
https://www.embarcadero.com/products/delphi/product-editions
Thanks in advance
