Bug 1915 - DrawLine Tool returns wrong StartPos and EndPos values
Summary: DrawLine Tool returns wrong StartPos and EndPos values
Version: TeeChart Pro Activex Control 2017.0.0.0 Release
Reported: 2017-09-07 07:09 EDT by yeray alonso
Modified: 2018-08-01 05:43 EDT (History)
Description yeray alonso 2017-09-07 07:09:42 EDT
In Delphi this works fine, but in ActiveX there are two problems:
- You get wrong values (very small) for StartPos.X, StartPos.Y, EndPos.X and EndPos.Y.
- In VB6 you get an "Object doesn't support this property or method" error when you try to use the AxisPoint function.
Find below the VCL code:
uses Series, TeeTools, TeCanvas;
var i: Integer;
  Chart1.View3D:=False;
  Chart1.Legend.Visible:=False;
  Chart1.Zoom.Active:=false;
  Chart1.AddSeries(TPointSeries).FillSampleValues;
  Chart1.Tools.Add(TDrawLineTool);
var i: Integer;
    StartPoint, EndPoint: TPoint;
  if (Chart1.Tools[0] is TDrawLineTool) then
    with (Chart1.Tools[0] as TDrawLineTool) do
      for i := 0 to Lines.Count-1 do
        Chart1.Canvas.TextOut(5, 10 * i, 'Line ' + IntToStr(i) + ', StartPos (' + FormatFloat('#,##0.##', Lines.Line[i].StartPos.X) + ', ' + FormatFloat('#,##0.##', Lines.Line[i].StartPos.Y) + ')' +
          ', EndPos (' + FormatFloat('#,##0.##', Lines.Line[i].EndPos.X) + ', ' + FormatFloat('#,##0.##', Lines.Line[i].EndPos.Y) + ')');
        StartPoint := AxisPoint(Lines.Line[i].StartPos);
        EndPoint := AxisPoint(Lines.Line[i].EndPos);
        Chart1.Canvas.Arrow(true, StartPoint, EndPoint, 8, 8, 0);
And here the VB code:
Private Sub Form_Load()
  TChart1.Aspect.View3D = False
  TChart1.AddSeries scPoint
  TChart1.Zoom.Enable = False
  TChart1.Tools.Add tcDrawLine
  Dim i As Integer
  Dim StartPoint, EndPoint As TeePoint2D
  With TChart1.Tools.Items(0).asDrawLine
    For i = 0 To .Lines.Count - 1
      'StartPoint = .AxisPoint(.Lines.Items(i).StartPos.X, .Lines.Items(i).StartPos.Y)
      'EndPoint = .AxisPoint(.Lines.Items(i).EndPos.X, .Lines.Items(i).EndPos.Y)
      'TChart1.Canvas.Arrow True, StartPoint.X, StartPoint.Y, EndPoint.X, EndPoint.Y, 8, 8, 0
      TChart1.Canvas.TextOut 5, 10 * i, "Line " + Str$(i) + ", StartPos (" + Str$(.Lines.Items(i).StartPos.X) + ", " + Str$(.Lines.Items(i).StartPos.Y) _
        + ", EndPos (" + Str$(.Lines.Items(i).EndPos.X) + ", " + Str$(.Lines.Items(i).EndPos.Y)
    Next i
  End With
