Bug 1904 - TeeGrid-Binary-1.02 Install Problem
Summary: TeeGrid-Binary-1.02 Install Problem
Product: TeeGrid for Delphi
: --- minor
Assignee: david berneda
Reported: 2017-08-10 11:50 EDT by psiegerist
Modified: 2018-04-19 08:16 EDT (History)
TeeGridInstall image (142.40 KB, image/jpeg)
2017-08-10 11:50 EDT, psiegerist
Description psiegerist 2017-08-10 11:50:22 EDT
Created attachment 775 [details]
I have installed RAD Studio Tokyo on a drive other than C due to size.  When your installation routine calls the TeeGridInstall.exe, it finds no available compiled environments to install.  If you come up with a null list, I suggest you add the ability to "point" to the directory that contains what you are looking far and that would rectify the problem.
I then tried loading the TeeGrid from the GitHub, but when I went to install from within Delphi, I receive errors during the install.  Here is the error: "Expected INITIALIZATION but received the end of file at line 483 (483:1)" - File Tee.Format
The file ends at that point.
Comment 1 sandra pazos 2018-02-27 10:36:45 EST
We don't reproduce the problem you're experiencing, using latest TeeGrid 1.04 version. I would like suggest you, download the latest trial version and check if the problem persist. You can download the TeeGrid not registered version from here: https://www.steema.com/downloads/gridvcl
Could you confirm us your results?
Thanks in advance
