Bug 1897 - TeeChart ActiveX control 64-bit does not work at all in address space above 4GB
Summary: TeeChart ActiveX control 64-bit does not work at all in address space above 4GB
Status: UNCONFIRMED
Version: TeeChart Pro Activex Control 2017.0.0.0 Release
: --- blocker
Reported: 2017-07-21 07:50 EDT by Krzysztof Zyczynski
Modified: 2017-07-21 07:50 EDT (History)
Sample application crashing TeeChart dll (149.23 KB, application/x-zip-compressed)
2017-07-21 07:50 EDT, Krzysztof Zyczynski
Description Krzysztof Zyczynski 2017-07-21 07:50:50 EDT
Created attachment 773 [details]
When we try to use TeeChart component and memory allocation is around 4GB or more at that time the dll simply crashes (even on CoCreateInstance). It happens when lower address space below 4GB is already used. This means the problem is most probably incorrect upgrade of component to 64bits (casting pointers to long etc).
We are developing a software that is processing large amount of telecommunication data and as a result RAM usage hits tens of gigabytes in some cases. As a result this problem is a BLOCKER for us.
Problem is visible in 64bit applications only: we are using version 2015 at the moment but the problem also exists with latest 2017 version.
To reproduce:
1. Grab a decent PC (8 - 16GB) with Windows 7 64bit installed (I was not testing it on 8 or 10 but probably the problem will be visible there as well).
2. Register TeeChart201764.ocx with regsvr32.exe
2. Create simplest application (WinAPI / DIalog or MFC) with COM support (CoInitialize(NULL); )
3. Allocate 4.5GB before doing anything with TeeChart
4. Create InProcess TChart component:
::CoCreateInstance(__uuidof(TChart), NULL, CLSCTX_INPROC_SERVER, __uuidof(IUnknown), (LPVOID*)&pUnk);
5. You should see an access violation
Please see attached sample application that is crashing immediatelly on CoCreateInstance call (see TeeCrashDemoDlg.cpp lines 104 - 112). Please change project settings to 64bit first.
Any questions / additional info request please let me know:
krzysztz@amdocs.com
Software Development Specialist
