Bug 1888 - Use of TeeGrid with AureliusDataset causes problems with EOF
Summary: Use of TeeGrid with AureliusDataset causes problems with EOF
Status: RESOLVED DUPLICATE of bug 1850
Product: TeeGrid for Delphi
Assignee: david berneda
Reported: 2017-07-11 08:31 EDT by Roland Kossow
Modified: 2017-07-17 10:31 EDT (History)
Description Roland Kossow 2017-07-11 08:31:15 EDT
I have a project in which I use a TeeGrid with a Datasource that is an Aurelius Dataset.
When I try to itterate through the Aurelius Dataset, the Next method of the dataset is not movinf the recordcursor, so that I never get an EOF = True.
Is this a known issue?
Comment 1 Roland Kossow 2017-07-11 08:35:50 EDT
The current workaround is to set Datasource of the TeeGrid to nil and after itterating through the Aurelisu dataset to set it to the dataset again which is not really cool :-)
Comment 2 Roland Kossow 2017-07-11 09:36:01 EDT
To be honest. This bug is no problem if one codes good.
That means it is no problem if I disable controls of the Aurelius dataset and enable them after my walking through the records.
But IMO it should also work without the disabling.
Comment 3 yeray alonso 2017-07-17 06:53:45 EDT
I believe this was fixed with http://bugs.teechart.net/show_bug.cgi?id=1850 and http://bugs.teechart.net/show_bug.cgi?id=1851
*** This bug has been marked as a duplicate of bug 1850 ***
Comment 4 Roland Kossow 2017-07-17 10:31:07 EDT
But it is not fixed in the current version.
