Bug 1871 - If is turned off "Link with Runtime packages" in C++ Builder a runtime exception appears.
Summary: If is turned off "Link with Runtime packages" in C++ Builder a runtime except...
Version: 21.170329
Reported: 2017-05-23 11:37 EDT by sandra pazos
Modified: 2017-05-23 11:41 EDT (History)
Message Error (26.56 KB, image/jpeg)
2017-05-23 11:41 EDT, sandra pazos
Description sandra pazos 2017-05-23 11:37:29 EDT
The problem isn’t produced using VCL code, is only produced by c++Builder.
To check the problem, use the code below with the "Link with Runtime packages" disabled.
void __fastcall TForm1::FormCreate(TObject *Sender)
		Series1 = new TLineSeries( this );
		Chart1->AddSeries(Series1);
		Series1->AddXY(3,40);
		 Series1->AddXY(12,23);
		 Series1->AddXY(8,3);
The code below in VCL with "Link with Runtime packages" disabled works fine.
Uses Series;
var Series1:TLineSeries;
procedure TForm3.FormCreate(Sender: TObject);
         Series1 :=  TLineSeries.Create(Self);
         Chart1.AddSeries(Series1);
         Series1.AddXY(3,40);
         Series1.AddXY(12,23);
         Series1.AddXY(8,3);
Comment 1 sandra pazos 2017-05-23 11:41:24 EDT
Created attachment 765 [details]
Message Error
