Bug 1860 - Application Verifier Warning SetProcessWorkingSetSize Incorrect Value
Summary: Application Verifier Warning SetProcessWorkingSetSize Incorrect Value
Status: IN_PROGRESS
Component: Visual C++ (show other bugs)
Version: TeeChart Pro Activex Control v2014 v2014.0.0.0 Release
: --- critical
Reported: 2017-05-11 15:32 EDT by Cerner
Modified: 2017-05-31 04:14 EDT (History)
Sample C++ project to repro the issue (202.77 KB, application/x-zip-compressed)
2017-05-17 18:35 EDT, Cerner
Updated version of the test app to correct header files (142.40 KB, application/x-zip-compressed)
2017-05-25 10:45 EDT, Cerner
Description Cerner 2017-05-11 15:32:04 EDT
While using WinDbg and Application Verifier (x64) we see a verifier stop message for the incorrect usage of SetProcessWorkingSetSize function call. Application verifier message details:
APPLICATION_VERIFIER_DANGEROUS_INVALID_MINIMUM_PROCESS_WORKING_SIZE (105)
SetProcessWorkingSetSize is called with MinimumWorkingSetSize = 0xFFFFFFFF.
Please use MinimumWorkingSetSize = (SIZE_T) -1.
This AppVerify messages seems to suggest Teechart is calling SetProcessWorkingSetSize using a value of 0xFFFFFFFF instead of (SIZE_T)-1. In a x64 process 0xFFFFFFFF is a valid large value and not -1. Will you please confirm the use of the SetProcessWorkingSetSize in TeeChart is correct?
Steps to Reproduce:
1. Create a small x64 VC++ test application using TeeChart201464.ocx.
2. Add the test application image (exe) to Application Verifer x64 with the basic option checked.
3. Use WinDbg x64 to run the test application.
4. Notice on create of the control an application verifier stop 105 will occur.
Comment 1 Cerner 2017-05-11 15:44:16 EDT
What TeeChart version are you using?
- File name: TeeChart201464.ocx
- Product Name: TeeChart Pro ActiveX Control v2014
- File Version: 2014.0.0.1
- Product Version: 2014.0.0.0
What IDE are you using?
 - Visual Studio 2015 Enterprise
What language are you programming with?
- Visual C++ / MFC / x64 project type
What exact OS are you running?
- Multiple: Windows 10 64-bit / Windows 2012 Server 64-bit
Comment 2 Cerner 2017-05-12 19:36:21 EDT
Sorry we missed a repro step:
Revised Steps to Reproduce:
3. Expand Miscellaneous and check DangerousAPIs.
4. Select Save.
5. Use WinDbg x64 to run the test application.
6. Notice on create of the control an application verifier stop 105 will occur.
Comment 3 Cerner 2017-05-17 18:35:56 EDT
Created attachment 762 [details]
Comment 4 Cerner 2017-05-22 17:57:07 EDT
What is the expected review and feedback cycle for bugs?
Comment 5 Cerner 2017-05-25 10:45:10 EDT
Created attachment 767 [details]
Comment 6 Cerner 2017-05-30 14:52:41 EDT
Tested version 2017.0.0 and the issue is still present.
