Bug 1842 - Series.Transparency will change to 100 when null values are added.
Summary: Series.Transparency will change to 100 when null values are added.
: High critical
Reported: 2017-04-17 07:02 EDT by Sunil Ramesh
Modified: 2018-01-26 08:22 EST (History)
Description Sunil Ramesh 2017-04-17 07:02:54 EDT
TeeChart v4.1.2017.03140
For most of the chart types Donut, Pie and others, adding null value will reset the transparency to 100.
         Donut donut = new Donut();
         tChart1.Series.Add(donut);
         donut.Add(2d);
         donut.Add(3d);
         //check the transparency value, it will be 0;
         MessageBox.Show(donut.Transparency.ToString());
         //add nullable
         donut.Add(new double?());
         //check the transparency value again, it will be now 100;
Also, when some properties under wall/aspect is changed, it will reset the series.Transparency to 100, making the series invisible.
Comment 1 Sunil Ramesh 2017-09-01 01:29:26 EDT
This issue is still reproducible, it is actually about the Transparency property returning 0 when called first time and 100 when called second time. The same happens to many chart types and elements that have Transparency property.
Run the below snippet and see the value of the 2nd message box.
         donut.Add(2d);
         donut.Add(3d);
         donut.Add(new double?());        //add null
         //check the transparency value, first time, it will be 0
         MessageBox.Show(string.Format("Transparency is correct: {0}", donut.Transparency));
         MessageBox.Show(string.Format("Transparency is wrong: {0}", donut.Transparency));
Comment 2 Sunil Ramesh 2017-09-01 01:38:04 EDT
(In reply to Sunil Ramesh from comment #0)
>          donut.Add(2d);
>          donut.Add(3d);
>          //add nullable
Comment 3 sandra pazos 2018-01-26 08:22:06 EST
Hello Sunil,
The problem you're experiencing is fixed for latest TeeChartFor.net 4.1.2017.10190
Thanks in advance
