Bug 1834 - PDF export of point chart with spherical points does not draw the spheres.
Summary: PDF export of point chart with spherical points does not draw the spheres.
Reported: 2017-04-06 10:59 EDT by Gary Desrochers
Modified: 2017-05-29 09:56 EDT (History)
Exported chart (19.22 KB, image/png)
2017-04-06 10:59 EDT, Gary Desrochers
Description Gary Desrochers 2017-04-06 10:59:35 EDT
Created attachment 751 [details]
Exported chart
Library version: Steema TeeChart for .NET 2017 4.1.2017.03140
IDE version: Developer's Studio 2015
.Net version: 4.0
Language: C#
OS: Windows 7 Ultimate 64-bit/Windows 10 64 bit
If a simple chart is created with a single Steema.TeeChart.Styles.Points series with pointer style of Sphere then exported as PDF the PDF file has blank spaces where the "Sphere"s should be.
Code example:
using System;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Text;
using System.Windows.Forms;
namespace SpherePDFExportIssue
            InitializeChart();
            Steema.TeeChart.Styles.Points TheSeries = new Steema.TeeChart.Styles.Points();
            TheSeries.Marks.Visible = false;
            TheSeries.Pointer.Pen.Visible = false;
            TheSeries.Pointer.Style = Steema.TeeChart.Styles.PointerStyles.Sphere;
            TheSeries.Pointer.HorizSize = 7;
            TheSeries.Pointer.VertSize = 7;
            TheSeries.ColorEach = true;
            TheSeries.FillSampleValues();
            tChart1.Series.Add(TheSeries);
            SaveFileDialog saveFileDialog1 = new SaveFileDialog();
            saveFileDialog1.Filter = "txt files (*.pdf)|*.pdf|All files (*.*)|*.*";
            saveFileDialog1.FilterIndex = 1;
            saveFileDialog1.RestoreDirectory = true;
            if (saveFileDialog1.ShowDialog() == DialogResult.OK)
                tChart1.Export.Image.PDF.Width = tChart1.Width;
                tChart1.Export.Image.PDF.Height = tChart1.Height;
                tChart1.Export.Image.PDF.Save(saveFileDialog1.FileName);
Drop a chart and a button on the form and use the above code.  Run the code and then push the button to save the chart as PDF.  Look at the output and you should see the same as the attachment.
