Bug 1800 - Tee.Grid.Totals unit not added to "uses" automatically
Summary: Tee.Grid.Totals unit not added to "uses" automatically
Product: TeeGrid for Delphi
Assignee: david berneda
Reported: 2017-02-23 04:10 EST by david berneda
Modified: 2017-02-23 10:03 EST (History)
Description david berneda 2017-02-23 04:10:00 EST
When adding a new "Totals" band (grid editor -> header or footer -> "+" button), the IDE does not automatically add the corresponding unit to the "uses" clause.
For example, for "Totals" bands, this is:  "uses Tee.Grid.Totals"
Because of this problem, running a project will raise an exception like: "TColumnTotals class not found"
The workaround is to manually add that units to the "uses" clause.
The solution is (similar to what we do in TeeChart with TeeGDIPlus), to create a new derived TSelectionEditor at VCL and FMX GridRegister.pas units.
See TeeChartReg.pas unit for examples:
  TTeeDBChartSelectionEditor = class(TSelectionEditor)
  public
    procedure RequiresUnits(Proc: TGetStrProc); override;
Comment 1 david berneda 2017-02-23 10:03:39 EST
Added new type:
 TTeeGridSelectionEditor=class(TSelectionEditor)
for both VCLTeeGridRegister and FMXTeeGridRegister units.
This method calls a new protected method at TCustomTeeGrid:
  function HasBandOfClass(const AClass:TGridBandClass):Boolean;
which is generic, to pass new GridBand classes in the future (if they are located in new units)
