Bug 1795 - MarksTip tool 'spinning' & not correctly rendering value with 3D stacked Bar series.
Summary: MarksTip tool 'spinning' & not correctly rendering value with 3D stacked Bar ...
: --- regression
Reported: 2017-02-21 05:48 EST by christopher ireland
Modified: 2017-02-21 06:12 EST (History)
Description christopher ireland 2017-02-21 05:48:36 EST
Code to produce:
      CreateChart();
      InitializeChart();
    TChart tChart1 = new TChart(false);
    private void CreateChart()
      splitContainer1.Panel2.Controls.Add(tChart1);
      tChart1.Aspect.Chart3DPercent = 75;
      Bar series1 = new Bar(tChart1.Chart);
      series1.MultiBar = MultiBars.Stacked;
      series1.FillSampleValues(2);
      Bar series2 = new Bar(tChart1.Chart);
      series2.MultiBar = MultiBars.Stacked;
      series2.FillSampleValues(2);
      MarksTip seriesMarksTip1 = new MarksTip(tChart1.Chart);
      seriesMarksTip1.Series = series1;
      seriesMarksTip1.GetText += MarkHandler;
      MarksTip seriesMarksTip2 = new MarksTip(tChart1.Chart);
      seriesMarksTip2.Series = series2;
      seriesMarksTip2.GetText += MarkHandler;
      tChart1[0].Transparency = 20;
      tChart1[1].Transparency = 20;
    private void MarkHandler(Steema.TeeChart.Tools.MarksTip sender, Steema.TeeChart.Tools.MarksTipGetTextEventArgs e)
      System.Diagnostics.Debug.WriteLine(sender.Series.Title);
Video screenshot of the issue:
https://www.screencast.com/t/h3bh63s02F
Comment 1 christopher ireland 2017-02-21 06:12:55 EST
The resolution to this issue is to use one MarksTip and not two, e.g.
      //seriesMarksTip1.Series = series1;
      //MarksTip seriesMarksTip2 = new MarksTip(tChart1.Chart);
      //seriesMarksTip2.Series = series2;
      //seriesMarksTip2.GetText += MarkHandler;
      double d = Convert.ToDouble(e.Text);
      if(tChart1[0].YValues.IndexOf(d) > -1)
        System.Diagnostics.Debug.WriteLine(tChart1[0].Title);
      else if(tChart1[1].YValues.IndexOf(d) > -1)
       System.Diagnostics.Debug.WriteLine(tChart1[1].Title);
which gives us the following screenvideo:
https://www.screencast.com/t/Q2iGMydHquil
The MarksTip tool is designed to work with multiple series by default, and only works with single series when the Series property is non-null.
