Bug 1793 - The AreaLines series doesn't hide when the AreaLines is set to false and alpha transparency is added
Summary: The AreaLines series doesn't hide when the AreaLines is set to false and alph...
Reported: 2017-02-21 04:07 EST by sandra pazos
Modified: 2017-03-01 04:38 EST (History)
screenshot (13.57 KB, image/png)
2017-03-01 04:34 EST, christopher ireland
screenshot2 (21.86 KB, image/png)
2017-03-01 04:37 EST, christopher ireland
Description sandra pazos 2017-02-21 04:07:53 EST
The AreaLines series doesn't hide when the AreaLines is set to false and alpha transparency is added.
The code below shows the problem:
            var area = new Steema.TeeChart.Styles.Area();
            area.AreaLines.Visible = false;
            area.LinePen.Visible = false;
            area.Color = Color.Purple;
            area.Transparency = 50;
            area.FillSampleValues();
            tChart1.Chart.Series.Add(area);}
Comment 1 christopher ireland 2017-03-01 04:34:43 EST
Created attachment 727 [details]
screenshot
This problem occurs outside of TeeChart as can be seen in the screenshot attached. The code to reproduce this is the following:
 public partial class UserControl1 : Control
    public UserControl1()
      ControlStyles s =
  ControlStyles.AllPaintingInWmPaint |
  ControlStyles.ResizeRedraw |
  ControlStyles.UserPaint |
  ControlStyles.SupportsTransparentBackColor |
  ControlStyles.Selectable |
  ControlStyles.StandardClick |
  ControlStyles.StandardDoubleClick;
      SetStyle(s, true);
			SetStyle(ControlStyles.OptimizedDoubleBuffer, true);
    public static void DoArea(Graphics g, Rectangle r)
      g.SmoothingMode = SmoothingMode.HighQuality;
      SolidBrush brush = new SolidBrush(Color.FromArgb(150, Color.Purple));
      int count = 15;
      int width = r.Width / count;
      Random rnd = new Random();
      Point oldRightTop = Point.Empty;
      for (int i = 0; i < count; i++)
        Rectangle shape = Rectangle.FromLTRB(r.Left + (width * i), r.Height - rnd.Next(r.Height), r.Left + (width * (i + 1)), r.Bottom);
        Point leftTop = shape.Location;
        Point rightTop = new Point(shape.Right, shape.Top);
        Point rightBottom = new Point(shape.Right, shape.Bottom);
        Point leftBottom = new Point(shape.Left, shape.Bottom);
        Point[] points = new Point[] { oldRightTop == Point.Empty ? leftTop : oldRightTop, rightTop, rightBottom, leftBottom };
        g.FillPolygon(brush, points);
        oldRightTop = rightTop;
    protected override void OnPaint(PaintEventArgs e)
      DoArea(e.Graphics, e.ClipRectangle);
    protected override void OnResize(EventArgs e)
      Invalidate();
The screenshot is this UserControl1 placed on a Windows Form.
Comment 2 christopher ireland 2017-03-01 04:37:44 EST
Created attachment 728 [details]
screenshot2
This is not a bug, as the problem occurs in a UserControl quite independently of TeeChart. To remedy this issue, please use SmoothingMode.HighSpeed (result seen in screenshot2):
      tChart1.Graphics3D.SmoothingMode = System.Drawing.Drawing2D.SmoothingMode.HighSpeed;
