Bug 1781 - When using the grid with an Aurelius Dataset I have a problem with an assertion in the code
Summary: When using the grid with an Aurelius Dataset I have a problem with an asserti...
Product: TeeGrid for Delphi
Assignee: david berneda
Reported: 2017-02-10 19:51 EST by Roland Kossow
Modified: 2017-02-16 05:40 EST (History)
Description Roland Kossow 2017-02-10 19:51:40 EST
As soon as I open a dataset that is associated with a TeeGrid I receive an assertion error that Seletced Row < 0 ...
procedure TGridSelection.SetRow(const Value: Integer);
  if Row<>Value then
    Assert(Value>=0,'Error: Selected Row < 0');
    DoChangeRow(Value);
    ResetRange;
    DoChanged;
Comment 1 david berneda 2017-02-16 05:40:27 EST
I've fixed this. The assertion is wrong (it should check against < -1 , not < 0).
"-1" means no row is selected (no cell gets selected at all).
Workaround is to compile with assertions off compiler option.
I'm very close to release a "nightly build v1.01" with this and many more fixes, I'll notify you when its available.
