Bug 1780 - SeriesGroups badly implemented causing an AV on TCHart.ClearChart.
Summary: SeriesGroups badly implemented causing an AV on TCHart.ClearChart.
Version: 17.160426
Reported: 2017-02-09 10:30 EST by h.hasenack
Modified: 2018-02-27 08:17 EST (History)
Description h.hasenack 2017-02-09 10:30:58 EST
Discovered the bug because my 64bit app was crashing when reloading a chart. the old chart was cleared before the new was loaded. But some seriesgroups were defined.
The seriesgroups collection was not cleared when the chart was cleared. a bit later I write the chart to a stream causing an AV in TSeriesGroup.Writeseries because the internal series pointer was pointing to a destroyed object.
My quikck fix was to add aSeriesGroups.Clear to the TChart.ClearChart method. IMO The real solution would be to implement a notification procedure for tcustomaxispanel that removes destroyed series from the seriesgroups as wel.
Comment 1 sandra pazos 2018-02-27 08:17:56 EST
The problem doesn't appear for me using latest TeeChart Pro VCL/FMX v2017.23.
Thanks in advance
