Bug 1767 - EIndexOutOfRange when loading a chart with series groups (Incl fix)
Summary: EIndexOutOfRange when loading a chart with series groups (Incl fix)
Version: 17.160426
Reported: 2017-02-07 05:06 EST by h.hasenack
Modified: 2018-02-27 08:34 EST (History)
Description h.hasenack 2017-02-07 05:06:41 EST
There is some code causing an EIndexOutOfrange error. I do not have the code to reproduce the error at hand as it involves quite some steps (by hand).
Here is the proposed fix in TeEngine.pas:
Procedure TCustomAxisPanel.Loaded;
var t, tt: Integer;
{$IFDEF HH_PATCH_TCustomAxisPanel_Loaded} // works around index out of range error
    idx:integer;
{$endif}
  inherited;
  if SeriesGroups.Count>0 then
    for t:=0 to SeriesGroups.Count-1 do
       with SeriesGroups[t] do
          try
            if (Assigned(FTempSeries)) and (FTempSeries.Count>0) then
              for tt:=0 to FSeries.Count-1 do
                FSeries.Delete(tt);
              for tt:=0 to FTempSeries.Count-1 do
                idx:=StrToInt(FTempSeries[tt]);
                if InRange(idx,0,SeriesList.Count-1) then
                  FSeries.Add(SeriesList.Items[idx]);
              end
{$else}
              FSeries.Add(SeriesList.Items[StrToInt(FTempSeries[tt])]);
{$endif}
          finally
            Freeandnil(FTempSeries);
Comment 1 sandra pazos 2018-02-27 08:34:10 EST
Hello
The problem, as told you in bug 1780 doesn't appear using TeeChart Pro VCL/FMX v2017.23.
Thanks in advance
