Bug 1740 - Snap cursor APIs fail to snap cursor chart to a series data plot. (TeeChart Pro ActiveX v7 ver7.0.1.4)
Summary: Snap cursor APIs fail to snap cursor chart to a series data plot. (TeeChart P...
Status: UNCONFIRMED
: Highest major
Reported: 2017-01-06 17:12 EST by Mike Dawn
Modified: 2017-01-11 11:41 EST (History)
Chart Series: Line
Sample of my Teechart setup (9.42 KB, text/plain)
2017-01-06 17:12 EST, Mike Dawn
Description Mike Dawn 2017-01-06 17:12:13 EST
Created attachment 691 [details]
Dear Steema Software Developer,
I am trying to get the snap cursor APIs to work. But Teechart fail to snap cursor to data series. In our code, we create Teechart graph in the dialog box as following steps. I also attach MyTeeChart.cpp as an example for you to see. Can you see my pseudo code and help me as to why put cursor snap APIs fail? Another option, Can you show the manual cursor snap to a fine granularity of 0.5 or 0.025 or 2 X-Axis increments value?
I also have Customer Number: I1211707
Teechart Version:
ActiveX control
File version: 7.0.1.4
Product Version: 7.0
1) Add one series data to the chart.
        m_pChart->Series(0)->Clear();
	VARIANT* vY = new VARIANT;
	vY->vt = VT_ARRAY | VT_R8;
	VARIANT* vX = new VARIANT;
	vX->vt = VT_ARRAY | VT_R8;
	long lSize = 0;
	m_pDisplayArray->BuildDisplayArray(nIndex,lSize,*vY,*vX);  <-- Build Variant Array
	m_pChart->Series(0)->AddArray(lSize,*vY,*vX);   <-- Add into Series 0
	delete vY;
	delete vX;
3) Scale X,Y to have 5% padding around the chart graph
2) Add tcCursor to ToolList and then set snap cursor
        //get tool list
	tchartNS::IToolListPtr pToolList(m_pChart->GetTools());
        //get 1st cursor
        m_lCursor1 = pToolList->Add((tchartNS::EToolClass)tcCursor);
	tchartNS::IToolsPtr pToolsPtr(pToolList->GetItems(m_lCursor1));
	m_pCursor = pToolsPtr->GetasTeeCursor();
        m_pCursorLine1 = pToolsPtr->GetasDrawLine();
        m_pCursor->PutStyle((tchartNS::ECursorToolStyle)cssVertical);
        m_pCursor->GetPen()->PutEndStyle((tchartNS::EPenEndStyle)esFlat);
	m_pCursor->GetPen()->PutColor(RGB(0,120,0));
	m_pCursor->PutSnap(VARIANT_TRUE);    <--- Why the cursor is not Snap to the series?
Comment 1 sandra pazos 2017-01-09 08:36:24 EST
Reviewing the code, you attached, I have seen you doesn’t assign any series to the tool. Also, you need set the CursorTool style property to both, because you can work with Snap propierty in correct way.
The simple code below, shows you what need do:
TChart1.AddSeries scPoint
TChart1.Tools.Add tcCursor
TChart1.Tools.Items(0).asTeeCursor.SnapStyle = ssVertical
TChart1.Tools.Items(0).asTeeCursor.Snap = True
TChart1.Tools.Items(0).asTeeCursor.Series = TChart1.Series(0)
Finally, I have realized you’re using Teechart Activex v7, could you please, download our Teechart Activex evaluation version from here:
https://www.steema.com/downloads/ax
And could you check if the problem persists?
Thanks in advance
Comment 2 Mike Dawn 2017-01-09 10:39:10 EST
Hello Sandra,
In my example, I get the tool list and add a cursor to it. I try to set series, but your APIs return a pointer to series and PutSeries(...) function requires VARIANT reference. Can you showed me the correct setup VARIANT value array that needs to pass in into PutSeries(...)?
//get tool list
//get 1st cursor
tchartNS::ISeriesPtr pSeries = m_pChart->GetaSeries(0);
pToolList->Items[0]->GetasTeeCursor()->PutSeries(pSeries);  <-- How convert to VARIANT values? Can you shown me how. I try to use variant array and I get exception.
TChart1.Tools.Items(0).asTeeCursor.Series = TChart1.Series(0)   <--- in C++?
Thank you for your help,
Mike
Comment 3 Mike Dawn 2017-01-11 11:41:25 EST
Hello Sandra,
Can you have a C++ developer looking into Series to VARIANT conversion?
VB Code:
C++ Code:
* I also see the question in Stackoverflow website that other developers have same problems. But there is no solutions to the post.
Mike
