Bug 174 - [TV52014364] Having a THorizBarSeries with BarWidthPercent=100, if you add the val...
Summary: [TV52014364] Having a THorizBarSeries with BarWidthPercent=100, if you add th...
Reported: 2009-08-25 17:09 EDT by yeray alonso
Modified: 2013-11-20 10:01 EST (History)
Description yeray alonso 2013-11-20 10:01:48 EST
1. Having a THorizBarSeries with BarWidthPercent=100, if you add the values with AddXY method and the first point has a bigger Y than the second, both them will be drawn at the same Y position. Also, if you hide the border, there is a space between the bars.
A workaround is to re-sort the valuelist.
The same happens in .NET v4 and the same workaround works on it too.
2. With YValues.Order set to both loNone or loDescending the suggested workaround seems to do nothing.
uses Series;
var i: Integer;
  Chart1.Legend.Visible:=false;
  with Chart1.AddSeries(THorizBarSeries) as THorizBarSeries do
    BarWidthPercent:=100;
    Pen.Visible:=false;
    ColorEachPoint:=true;
    //YValues.Order:=loDescending; //2. workaround break
    for i:=4 downto 0 do
      AddXY(random*100, i);
    //YValues.Sort; //1. workaround
end; [created:2009-08-25T16:09:46.000+01:00 reported by:yeray@steema.com reported in version:9.0 (TeeChart VCL)]
