Bug 1698 - depth returns Infinity in build 4.1.2016.10260
Summary: depth returns Infinity in build 4.1.2016.10260
: --- critical
Reported: 2016-11-28 02:30 EST by Sunil Ramesh
Modified: 2016-11-29 06:14 EST (History)
sample project (15.90 KB, application/x-zip-compressed)
2016-11-28 02:30 EST, Sunil Ramesh
Description Sunil Ramesh 2016-11-28 02:30:53 EST
Created attachment 666 [details]
sample project
run the below code in build 4.1.2016.10260 and 4.1.2016.05120
in 4.1.2016.10260 it returns infinity where as 4.1.2016.05120 and earlier returns non-infinity values.
I am also attaching a sample project, run it in debug to see the output for the above versions.
         Surface s = new Surface(tChart1.Chart);
         s.Add(1, 0.021277799637864005d, 1);
         s.Add(2, 0.03886656098240001d, 2);
         s.Add(3, 0.03886156098240001d, 3);
         s.Add(4, 0.021277399637864005d, 4);
         s.Add(1, 0.03886236098240001d, 1);
         s.Add(2, 0.03886356098240001d, 2);
         s.Add(3, 0.03986356092240001d, 3);
         s.Add(4, 0.03886356098240001d, 4);
         s.Add(1, 0.03886356098240001d, 1);
         s.Add(2, 0.021277799637864005d, 2);
         s.Add(3, 0.03886356058240001d, 3);
         s.Add(4, 0.03886356048240001d, 4);
         s.Add(1, 0.03886256098240001d, 1);
         s.Add(2, 0.03886156098240001d, 2);
         s.Add(3, 0.03886316098240001d, 3);
         s.Add(4, 0.03886351098240001d, 4);
         tChart1.Series.Add(s);
      private void tChart1_GetAxisLabel(object sender, GetAxisLabelEventArgs e)
         if (sender.Equals(tChart1.Axes.Depth))
            double dv = double.Parse(e.LabelText);
            Debug.WriteLine("depth: {0}, Infinity? {1}", e.LabelText, double.IsInfinity(dv));
         tChart1.Graphics3D.SmoothingMode = SmoothingMode.HighQuality;
         tChart1.Graphics3D.BufferStyle = BufferStyle.OptimizedBuffer;
         tChart1.Aspect.ClipPoints = true;
         tChart1.Aspect.Chart3DPercent = 90;
         tChart1.Aspect.Elevation = 348;
         tChart1.Aspect.Perspective = 62;
         tChart1.Aspect.Rotation = 329;
         tChart1.Aspect.SmoothingMode = SmoothingMode.HighQuality;
         tChart1.Aspect.TextRenderingHint = TextRenderingHint.ClearTypeGridFit;
         tChart1.Aspect.Zoom = 70;
         tChart1.Axes.Depth.MaximumOffset = 3;
         tChart1.Axes.Depth.MinimumOffset = 3;
         tChart1.Axes.Depth.Title.Font.Size = 7;
         tChart1.Axes.Depth.AxisPen.Width = 1;
         tChart1.Axes.Depth.Labels.Font.Size = 7;
         tChart1.Axes.Depth.Visible = true;
//output 4.1.2016.10260
depth: 0, Infinity? False
depth: 1, Infinity? False
depth: 0.5, Infinity? False
depth: ∞, Infinity? True
//output 4.1.2016.05120
Comment 1 marc meumann 2016-11-29 06:14:07 EST
Problem caused by increased precision of minimim axis increment value in latest release.
Fixed in code for next release.
Workaround available in current version:
Set Axis (in this case Depth) minimum increment value:
tChart1.Axes.Depth.MinAxisIncrement = 1e-50;
