Bug 1684 - Consider axis labels multiline when calculating the height of the Chart Rect
Summary: Consider axis labels multiline when calculating the height of the Chart Rect
Version: 20.170306
Target Milestone: v2017.20
Assignee: yeray alonso
Reported: 2016-11-14 08:10 EST by yeray alonso
Modified: 2017-03-17 05:19 EDT (History)
Description yeray alonso 2016-11-14 08:10:07 EST
If you are setting multi-line labels through AxisValuesFormat/DateTimeFormat, only one line is considered when calculating the chart height. So some of these lines can be drawn out of the chart rect. Ie:
uses Series;
  Chart1.Legend.Visible:=false;
  with Chart1.AddSeries(TFastLineSeries) as TFastLineSeries do
    //XValues.DateTime:=true;
    FillSampleValues;
  //Chart1.Axes.Bottom.DateTimeFormat:='dd/mm/yyyy' + sLineBreak + 'hh:mm' + sLineBreak + 'sss';
  Chart1.Axes.Bottom.AxisValuesFormat:='#,##0.###'+sLineBreak+'hello'+sLineBreak+'world';
