Bug 1645 - Upgrade TeeCHart Version 1.1 (old) to Latest TeeChart 4.1.2016.05125 error when try to view Pie Chart Vertical
Summary: Upgrade TeeCHart Version 1.1 (old) to Latest TeeChart 4.1.2016.05125 error wh...
Status: RESOLVED DUPLICATE of bug 1696
Component: WebChart (show other bugs)
: --- critical
Reported: 2016-10-05 22:48 EDT by Deepak Verma
Modified: 2016-12-01 05:50 EST (History)
screenshot (19.00 KB, image/png)
2016-10-06 06:24 EDT, christopher ireland
result of code (10.64 KB, image/png)
2016-10-07 07:06 EDT, christopher ireland
code (34.38 KB, image/png)
2016-10-07 07:07 EDT, christopher ireland
Description Deepak Verma 2016-10-05 22:48:07 EDT
Hi Team,
Our development team upgrading TeeChart Version 1.1 (old) to Latest TeeChart 4.1.2016.05125, showing error when try to view Pie Chart Vertical.
Other charts can view correctly but giving below error for Pie Chart Vertical:
"Object reference not set to an instance of an object"
This is very urgent for or development purpose and stuck to proceed with this issue.
Please help and suggest the required things for this.
Deepak Verma
deepak.verma@exact.com
Comment 1 christopher ireland 2016-10-06 03:46:45 EDT
Hello Deepak,
Could you please send us a Minimal, Complete, and Verifiable example (specified here: http://stackoverflow.com/help/mcve ) with which we can reproduce your issue? Some screenshots of what you are expecting to see would also be appreciated.
Thank you.
Comment 2 Deepak Verma 2016-10-06 05:38:07 EDT
Hello Christopher,
Thank you for your response, please find sample code which we are using for our Pie Charts, please note this is working correctly with TeeChart dll 1.1, but with latest DLL, this throwing error at line "chart.Series.Add(pie)"  .
Dim chart As Chart = New Chart
With chart
	.Panel.Bevel.Outer = Steema.TeeChart.Drawing.BevelStyles.None
	.Panel.Bevel.ColorTwo = System.Drawing.Color.White
	.Panel.Bevel.Width = 0
	.Panel.Color = System.Drawing.Color.White
	.Panel.Brush.Color = System.Drawing.Color.White
	.Width = width
	.Height = height
	.Header.Visible = False
.Aspect.SmoothingMode = System.Drawing.Drawing2D.SmoothingMode.HighQuality
	.Panel.MarginBottom = 0
	.Panel.MarginLeft = 0
	.Panel.MarginRight = 0
	.Panel.MarginTop = 0
	.Aspect.View3D = False
End With
	Dim bottomAxis As Steema.TeeChart.Axis = chart.Axes.Bottom
	bottomAxis.Labels.Separation = 0
	bottomAxis.Labels.MultiLine = True
	bottomAxis.MinorTicks.Visible = True
	chart.Legend.Visible = Not (legendMode = ChartLegend.None)
Dim pie As Steema.TeeChart.Styles.Pie = New Steema.TeeChart.Styles.Pie
	pie.Marks.Style = Styles.MarksStyles.LabelPercent
	pie.Circled = True
	For i As Integer = 0 To Me.items.HorizontalItemCount - 1
	Dim hItem As MyItem = Me.items.HorizontalItem(i)
' Our code for getting values, for your testing you can add ardcoded values
pie.Add(hItem.Total.First, hItem.description, DefaultColor.GetColor(i))
	Next
If Me.items.showHorizontalOther Then
	Dim otherTotal As AnalysisValues = CreateMyValues()
For i As Integer = 0 To Me.items.VerticalItemCount - 1
	Dim vItem As MyItem = Me.items.VerticalItem(i)
	otherTotal.Add(vItem.Other)
Next
If Me.items.showVerticalOther Then
	otherTotal.Add(Me.items.otherOther)
End If
pie.Add(otherTotal.First, termOther, DefaultColor.GetColor(Me.items.HorizontalItemCount))
	End If
' This Line throwing Object reference error to us, This was working correctly with old version 1.1
Comment 3 christopher ireland 2016-10-06 06:24:14 EDT
Created attachment 651 [details]
screenshot
Comment 4 christopher ireland 2016-10-06 06:25:56 EDT
Hello -
Using a Windows Form with a TChart added at desigtime, and exactly this code:
  Private Sub Form1_Load(sender As System.Object, e As System.EventArgs) Handles MyBase.Load
    InitializeChart()
  Sub InitializeChart()
    With chart
      .Width = Width
      .Height = Height
    End With
    pie.Circled = True
    pie.FillSampleValues()
    TChart1.Chart = chart
I get a chart identical to the screenshot attached. In your Web Form, how are you assigning the chart variable to the WebChart, exactly?
Comment 5 Deepak Verma 2016-10-06 12:07:47 EDT
I have tried with your code as well, but still same error at line
I am using this code for webform, not window, is this correct for web as well.
Comment 6 christopher ireland 2016-10-07 07:06:36 EDT
Created attachment 652 [details]
result of code
Comment 7 christopher ireland 2016-10-07 07:07:07 EDT
Created attachment 653 [details]
code
Comment 8 christopher ireland 2016-10-07 07:09:13 EDT
In the attachment "code" you will see the code I have used in a Web Form project. In the attachment "result of code" you will see the result of running this code.
No errors were thrown when running this code, and the result is as expected.
My question is: how do you connect up the code in this test to the WebChart which is on the Web Form? Without any connection, as in this code, the result is an empty WebChart.
Comment 9 Deepak Verma 2016-10-08 06:25:59 EDT
Thank You Christopher, I am checking this code and let you know if this works fine for me as well. I will our existing implementation which was fine for old version and compare with new version.
Thanks You
Comment 10 Deepak Verma 2016-11-25 02:34:58 EST
Hi Christopher, Sorry to get back after long time.
Now We are implementing/upgrading new teechart DLL and getting this error while debug.
 at Steema.TeeChart.Styles.Series.GetLanguageSpecificTitle()
   at Steema.TeeChart.Styles.Series.Added()
   at Steema.TeeChart.Styles.SeriesCollection.Add(Series s)
Please suggest the reason and what need to do to fix this.
Comment 11 christopher ireland 2016-12-01 05:50:07 EST
*** This bug has been marked as a duplicate of bug 1696 ***
