Bug 1636 - [TF02016328] Bar series overlap when the bottom axis minimum and maximum aren't automatic.
Summary: [TF02016328] Bar series overlap when the bottom axis minimum and maximum aren...
Reported: 2016-09-22 09:33 EDT by christopher ireland
Modified: 2016-09-22 09:44 EDT (History)
Chart Series: Bar
Description christopher ireland 2016-09-22 09:33:40 EDT
If you add a Bar Series with a determinate range of values, disable the automatic Minimum and Maximum of bottom axis; assign other range, more big. The Bars overlap. Would be interesting Bar Series is recalculating the BarWidthPercent automatically, and adapting it to the range of bottom axis when it isn't automatic to get good results.
See next code to reproduce the problem:
tChart1.Axes.Bottom.Automatic = false;
tChart1.Axes.Bottom.Minimum = 0;
tChart1.Axes.Bottom.Maximum = 10;
Steema.TeeChart.Styles.Bar bar = new Steema.TeeChart.Styles.Bar(tChart1.Chart);
bar.Add(1, 1000);
bar.Add(2, 1200);
bar.Add(3, 900);
bar.Add(4, 800);
A workaround to solve this problem is changing manually the BarWidthPercent.
