Bug 1596 - cpoPrintPanel doesn’t work properly when is disable.
Summary: cpoPrintPanel doesn’t work properly when is disable.
Component: Print (show other bugs)
Version: 18.160504
Reported: 2016-08-12 06:22 EDT by sandra pazos
Modified: 2016-08-12 06:22 EDT (History)
Print Test (52.53 KB, application/x-zip-compressed)
2016-08-12 06:22 EDT, sandra pazos
Description sandra pazos 2016-08-12 06:22:24 EDT
Created attachment 630 [details]
Print Test
I expect if the property cpoPrintPanel is disable the print output exports the chart in same color as ChartPreviewer paper color, but always is white. If active the AsBitmap property that works in correct way.
The attached project reproduce the problem.
