Bug 1591 - The line pen color isn’t drawn smoothed although Chart is smoothed.
Summary: The line pen color isn’t drawn smoothed although Chart is smoothed.
Reported: 2016-08-03 06:19 EDT by sandra pazos
Modified: 2016-08-16 09:32 EDT (History)
FastLine Smoothed (81.84 KB, image/jpeg)
2016-08-03 06:19 EDT, sandra pazos
usercontrol screenshot (4.67 KB, image/png)
2016-08-16 09:30 EDT, christopher ireland
Description sandra pazos 2016-08-03 06:19:41 EDT
Created attachment 625 [details]
FastLine Smoothed
The problem is produced when you do zoom in the Chart or customize the Axes scale with SetMinMax.
The problem is evident, if you set the pen color red or green.
The code below shows the problem:
  Steema.TeeChart.Styles.FastLine fastLine1;
            fastLine1 = new Steema.TeeChart.Styles.FastLine(tChart1.Chart);
            double[] xValues = new double[11];
            for (int i = 0; i < 11; i++)
                xValues[i] = 36951 + i * 360;
            double[] yValues = new double[] { 873, 871, 869, 867, 865, 863, 861, 859, 857, 853, 851 };
            fastLine1.Add(xValues, yValues);
            fastLine1.XValues.DateTime = true;
            fastLine1.Color = Color.Red;
            fastLine1.LinePen.Width = 2;
            tChart1.Axes.Left.SetMinMax(400, 900);
Also I have attached an image that shows the problem
Comment 1 christopher ireland 2016-08-16 09:30:24 EDT
Created attachment 631 [details]
Comment 2 christopher ireland 2016-08-16 09:32:33 EDT
This appears to be an issue with WinForms GDI+, and is not specific to TeeChart. To see this issue in action independently of TeeChart, please use the code for the usercontrol below:
  public partial class UserControl1 : UserControl
    public UserControl1()
      XValues = new List<int>();
      YValues = new List<int>();
      MarginBottom = 0;
    public List<int> XValues { get; set; }
    public List<int> YValues { get; set; }
    public int MarginBottom { get; set; }
    private int CalcXPos(int xValue)
      double range = XValues.Max() - XValues.Min();
      double ratio = rect.Width / range;
      return(int)Math.Round(ratio * (xValue - XValues.Min()));
    private int CalcYPos(int yValue)
      double range = YValues.Max() - YValues.Min();
      int height = rect.Height - MarginBottom;
      double ratio = height / range;
      return height - (int)Math.Round(ratio * (yValue - YValues.Min()));
    private Rectangle rect;
    protected override void OnPaint(PaintEventArgs e)
      rect = e.ClipRectangle;
      Graphics g = e.Graphics;
      g.SmoothingMode = System.Drawing.Drawing2D.SmoothingMode.HighQuality;
      g.FillRectangle(Brushes.Yellow, rect);
      for (int i = 0; i < XValues.Count; i++)
        Point p0 = Point.Empty;
        Point p1 = new Point(CalcXPos(XValues[i]), CalcYPos(YValues[i]));
        if(i > 0)
          p0 = new Point(CalcXPos(XValues[i - 1]), CalcYPos(YValues[i - 1]));
          Pen pen = new Pen(Color.Red, 2.0f);
          g.DrawLine(pen, p0, p1);
this usercontrol can be hosted in a WinForm like this:
    public Form2()
      this.Width = 750;
      this.Height = 550;
      UserControl1 control1 = new UserControl1();
      control1.Dock = DockStyle.Fill;
      this.Controls.Add(control1);
      int[] xValues = new int[11];
      int[] yValues = new int[] { 873, 871, 869, 867, 865, 863, 861, 859, 857, 853, 851 };
      control1.XValues.AddRange(xValues);
      control1.YValues.AddRange(yValues);
      control1.MarginBottom = this.Height - 75;
the result can be seen in the image attached, "usercontrol screenshot".
