Bug 1578 - Area series cannot handle stacked positive and negatiove values properly
Summary: Area series cannot handle stacked positive and negatiove values properly
Version: 150901
Reported: 2016-07-14 05:04 EDT by h.hasenack
Modified: 2016-07-14 05:14 EDT (History)
Chart Series: Area
The unpatched result (nitice yellow series drawon over green seirs, making values of green series impossible to analyse (98.55 KB, image/jpeg)
2016-07-14 05:09 EDT, h.hasenack
Patch installed. crossing x axis still ugly but at leas values are displayed correctly (111.95 KB, image/jpeg)
2016-07-14 05:10 EDT, h.hasenack
Description h.hasenack 2016-07-14 05:04:22 EDT
When using a stacked areas, with mixed positive and negative values the areas are rendered in a very confusing way. Check the attached screenshots for with and without my patch.
the patched version is onlu "ugly" when the value crosses the x-axis, the unpatched version is ugly and dead wrong.
Comment 1 h.hasenack 2016-07-14 05:09:50 EDT
Created attachment 617 [details]
Comment 2 h.hasenack 2016-07-14 05:10:41 EDT
Created attachment 618 [details]
Comment 3 h.hasenack 2016-07-14 05:14:25 EDT
Patches applied to series.pas (using condition compiling for HH_PATCH_TC_STACKEDAREA)
interface
  TCustomSeries=class(TCustomLineSeries)
    Function PointOrigin(ValueIndex:Integer; SumAll:Boolean):Double;  {$ifdef HH_PATCH_TC_STACKEDAREA} virtual; {$endif}
  TAreaSeries=Class(TCustomSeries)
{$IFDEF HH_PATCH_TC_STACKEDAREA}
    Function PointOrigin(ValueIndex:Integer; SumAll:Boolean):Double; override;
{$ENDIF}  public
implementation
// negative values are wrongly stacked in the original code. This overriden
// function calculates the correct origin value for each datapoint
Function TAreaSeries.PointOrigin(ValueIndex:Integer; SumAll:Boolean):Double;
   Function LocalPointOrigin:Double;
   var t         : Longint;
       tmpSeries : TChartSeries;
       val:double;
       sumneg,sumpos:boolean;
   Begin
     result:=0;
     // first of determine wheter we have to sum negative or positive values
     val:=MandatoryValueList[ValueIndex];
     sumneg:=val<0;
     sumpos:=val>=0;
     if Assigned(ParentChart) then with ParentChart do
       if SumPos then
         for t:=0 to SeriesList.Count-1 do
         Begin
           tmpSeries:=Series[t];
           if (not SumAll) and (tmpSeries=Self) then
             Break
           With tmpSeries do
           if Active and SameClass(Self) and (tmpSeries.Count>ValueIndex) then
             val:=GetOriginValue(ValueIndex);
             if (val>=0.0) and sumpos then
               result:=result+val
         end
       end
       else if SumNeg then
         Begin
             Break
           With tmpSeries do
             if (val<0.0) then
               result:=result+val
       end
Begin
  if MultiArea in [maStacked,maStacked100] then
    result:=LocalPointOrigin
  else result:=inherited PointOrigin(ValueIndex,SumAll);
End;
{$ENDIF}
