Bug 1573 - TeeChart Paint Event is Not Firing
Summary: TeeChart Paint Event is Not Firing
Reported: 2016-06-29 09:03 EDT by narcís calvet
Modified: 2016-07-05 04:35 EDT (History)
Description narcís calvet 2016-06-29 09:03:24 EDT
We are not getting TeeChart's Paint Event on Runtime. For other controls Paint event is getting called successfully. AfterDraw event works fine instead. Code to reproduce the problem:
      InitializeChart();
      var series = new Steema.TeeChart.Styles.Points(tChart1.Chart);
      series.FillSampleValues();
      tChart1.Paint += TChart1_Paint;
      //tChart1.AfterDraw += TChart1_AfterDraw;
      tChart1.MouseMove += TChart1_MouseMove;
    private void TChart1_AfterDraw(object sender, Steema.TeeChart.Drawing.Graphics3D g)
      g.Pen.Color = Color.Red;
      g.Line(new Point(0, MouseLocation.Y), new Point(Width, MouseLocation.Y));
      g.Pen.Color = Color.Black;
      g.Line(new Point(MouseLocation.X, 0), new Point(MouseLocation.X, Height));
    private void TChart1_MouseMove(object sender, MouseEventArgs e)
      MouseLocation = e.Location;
      tChart1.Invalidate(); //or tChart1.Draw();
    Point MouseLocation;
    private void TChart1_Paint(object sender, PaintEventArgs e)
      e.Graphics.DrawLine(Pens.Red, new Point(0, MouseLocation.Y), new Point(Width, MouseLocation.Y));
      e.Graphics.DrawLine(Pens.Black, new Point(MouseLocation.X, 0), new Point(MouseLocation.X, Height));
Comment 1 christopher ireland 2016-07-05 04:35:56 EDT
The reason the Paint event is not firing is because the TChart class overrides the OnPaint virtual method but does not make a call to base.OnPaint. The reason it does not make a call to base.OnPaint is because of the custom graphics buffering TChart uses.
If, for whatever reason, you wish to draw in the Paint method, you will have to derive a custom class from TChart and override the OnPaint method.
