Bug 1545 - Index out of range when series is drawing
Summary: Index out of range when series is drawing
Version: 150901
: High critical
Reported: 2016-05-19 11:19 EDT by IMT
Modified: 2021-04-21 03:01 EDT (History)
3 users (show)
Chart Series: Line
Delphi / C++ Builder RAD IDE Version: RAD XE7
Description IMT 2016-05-19 11:19:18 EDT
Just discovered a bug in the latest build for VCL. The only thing required to reproduce is to recompile TeeChart with Range checking.
Function TCustomSeries.DoDrawAll contains the bug on the line 4104:
DoDrawPointers(True,P[tmpIndex]);
tmpIndex - is wrong if tmpFraction is False. You are trying to address wrong tmpIndex = max. index + 1. To solve it quick, just replace above
      if tmpFraction then
        tmpValue:=XValues.Value[t-1]+tmpFractionValue;
        P[tmpIndex].X:=CalcXPosValue(tmpValue);
        P[tmpIndex].Y:=CalcPosLeftRight(tmpValue,tmpIndex-1,tmpIndex);
with
      if tmpFraction then
      end
        dec(tmpIndex);
It might help. Thank you very much!
Comment 1 IMT 2016-05-20 04:16:56 EDT
I forgot to add that you need to have all series points visible.
Comment 2 marc meumann 2021-04-21 03:01:56 EDT
I see the code mod is in there and this issue should have been closed down. Late to day, but thx for the observation.
