Bug 152 - [TV52013143] Attached you can find TeeCharts Hoch.tee and Quer.tee, Hoch.tee with ...
Summary: [TV52013143] Attached you can find TeeCharts Hoch.tee and Quer.tee, Hoch.tee ...
Reported: 2008-06-19 10:47 EDT by narcís calvet
Modified: 2013-11-20 10:00 EST (History)
Description narcís calvet 2013-11-20 10:00:29 EST
Attached you can find TeeCharts Hoch.tee and Quer.tee, Hoch.tee with vertical bars and Quer.tee with horizontal bars.
We want that the red bars begin at the end of the yellow bars. If the values are both positive or both negative it is no problem. But if one of the values is positive and the other is negative, I can with vertical bars only solve the problem with offsets. I write the values of the second bar also to the offset of the third bar.
In the horizontal bars I can't solve the problem like this, because I can't enter offsets in the datas.
I looked at the features demo and got the same problem.
Here is a Hardcopy:
(see attached image)
I clicked Edit and then Data and changed values to negative values. The Bars with negative values begin at the 0 and not at the end of the other Bars.
One sentence I want to tell:
It will be easy for me, if I can enter offsets in horizontal bars like in vertical bars.
I hope it will be possible in the next release.
 [created:2008-06-19T09:47:22.000+01:00 reported by:narcis@steema.com reported in version:8.03 (TeeChart VCL)]
