Bug 1505 - Access Violation in module TeeChart201564.ocx
Summary: Access Violation in module TeeChart201564.ocx
Status: UNCONFIRMED
Version: TeeChart Pro Activex Control v2015 v2015.0.0.2 Release
: --- blocker
: 1465 (view as bug list)
Reported: 2016-04-12 06:01 EDT by fredj9988
Modified: 2016-05-26 06:10 EDT (History)
Chart.zip (232.16 KB, application/zip)
2016-04-12 06:01 EDT, fredj9988
Chart (Updated) (441.83 KB, application/zip)
2016-05-03 04:58 EDT, fredj9988
Description fredj9988 2016-04-12 06:01:42 EDT
Created attachment 587 [details]
Chart.zip
When there are huge number of memory allocations performed, the OCX fails to load. It happens with the versions 2015.0.0.2 and 2015.0.0.3.
Our application is highly memory intensive, therefore the OCX fails.
We have created a sample application (attached) to simulate our application.
IMPORTANT (please refer to the sample application first):
1. When the OCX is loaded before performing any huge memory allocations, then the problem vanishes.
2. If the count does not reproduce the error, then increase it by the factor of 50000 or 100000.
The attachment includes:
1. MFCApplication8: A sample application (File: MFCApplication8Dlg.cpp; Method: OnInitDialog())
2. Error.png: A screenshot of the error
Environment:
MFC
Visual Studio Pro 2013
Windows 7 64bit
RAM: 16GB
Processor: Intel Core i5-4570 CPU @3.20GHz 3.20GHz
Thanks!
Comment 1 fredj9988 2016-04-12 06:02:21 EDT
*** Bug 1465 has been marked as a duplicate of this bug. ***
Comment 2 sandra pazos 2016-04-15 10:59:22 EDT
The application you attached, doesn't compile and doesn't run for us. Could you please, attach again a project we can compile and execute, because we try to reproduce the problem you are experiencing?
Thanks for your collaboration
Regards
Comment 3 fredj9988 2016-04-18 12:12:55 EDT
Could you please let me know what problems are you having with the attached sample? So I can fix those in the new sample.
The attached sample can be used in virtually any version of Visual Studio.
Thanks!
Comment 4 sandra pazos 2016-04-19 07:25:12 EDT
There is an incorrect include path, specifically, the below:
 #include "W:\Src\AOs\Charting\teechart2015.tlh"
Also, there isn't any chart in the project.
Thanks in advance
Comment 5 fredj9988 2016-05-03 04:58:36 EDT
Created attachment 600 [details]
Chart (Updated)
Attachment updated
Comment 6 fredj9988 2016-05-03 05:00:04 EDT
Apologies for the delayed response!!!
The project in the attachment has been updated and the missing files have been added.
Thanks!
Comment 7 fredj9988 2016-05-26 06:10:27 EDT
Hi there,
I would be great if I can get some update.
Thanks!
