Bug 1491 - Some Themes aren't updated the 3Dview when you change the theme by editor
Summary: Some Themes aren't updated the 3Dview when you change the theme by editor
Reported: 2016-04-04 05:09 EDT by sandra pazos
Modified: 2016-05-03 11:48 EDT (History)
Themes Example (11.87 KB, application/x-zip-compressed)
2016-04-04 05:09 EDT, sandra pazos
Description sandra pazos 2016-04-04 05:09:20 EDT
Created attachment 580 [details]
Themes Example
Some Themes aren't updated the 3Dview when you change the theme by editor, for example ReportTheme. The problem doesn't appear if you work by code. To reproduce the problem, use the attached project and follow the steps below:
1-	Run the project
2-	Click Editor button
3-	Go to Themes tab and select again ReportTheme
The problem appears, here. Is necessary force draw the Chart.
