Bug 1466 - Errors when exporting to XML file in SWT
Summary: Errors when exporting to XML file in SWT
Version: 3.2015.0108
Reported: 2016-03-11 09:50 EST by yeray alonso
Modified: 2016-03-11 09:50 EST (History)
Description yeray alonso 2016-03-11 09:50:39 EST
Errors when exporting to XML file in SWT. Even with the errors, the xml file is generated and can be imported later, this time without errors.
In Swing you can both export and import without errors.
	private static void createSimpleBar() {
		Bar bar1 = new Bar(tChart1.getChart());
		bar1.setColorEach(true);
		bar1.fillSampleValues();
	static String fileName = "E:\\tmp\\testJava.xml";
	private static void xmlExport() {
		try {
			tChart1.getExport().getTemplate().toXML(fileName);
		} catch (FileNotFoundException e) {
			e.printStackTrace();
Errors:
java.lang.InstantiationException: com.steema.teechart.TChart
	at java.lang.Class.newInstance(Unknown Source)
	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
	at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
	at java.lang.reflect.Method.invoke(Unknown Source)
	at sun.reflect.misc.Trampoline.invoke(Unknown Source)
	at sun.reflect.GeneratedMethodAccessor1.invoke(Unknown Source)
	at sun.reflect.misc.MethodUtil.invoke(Unknown Source)
	at java.beans.Statement.invokeInternal(Unknown Source)
	at java.beans.Statement.access$000(Unknown Source)
	at java.beans.Statement$2.run(Unknown Source)
	at java.security.AccessController.doPrivileged(Native Method)
	at java.beans.Statement.invoke(Unknown Source)
	at java.beans.Expression.getValue(Unknown Source)
	at java.beans.Encoder.getValue(Unknown Source)
	at java.beans.Encoder.get(Unknown Source)
	at java.beans.PersistenceDelegate.writeObject(Unknown Source)
	at java.beans.Encoder.writeObject(Unknown Source)
	at java.beans.XMLEncoder.writeObject(Unknown Source)
	at java.beans.Encoder.writeExpression(Unknown Source)
	at java.beans.XMLEncoder.writeExpression(Unknown Source)
	at java.beans.DefaultPersistenceDelegate.doProperty(Unknown Source)
	at java.beans.DefaultPersistenceDelegate.initBean(Unknown Source)
	at java.beans.DefaultPersistenceDelegate.initialize(Unknown Source)
	at java.beans.Encoder.writeObject1(Unknown Source)
	at java.beans.Encoder.cloneStatement(Unknown Source)
	at java.beans.Encoder.writeStatement(Unknown Source)
	at java.beans.XMLEncoder.writeStatement(Unknown Source)
	at com.steema.teechart.exports.TemplateExport.toXML(TemplateExport.java:168)
	at com.steema.teechart.exports.TemplateExport.toXML(TemplateExport.java:109)
	at com.steema.teechart.exports.TemplateExport.toXML(TemplateExport.java:98)
	at Test.xmlExport(Test.java:61)
	at Test.main(Test.java:39)
Caused by: java.lang.NoSuchMethodException: com.steema.teechart.TChart.<init>()
	at java.lang.Class.getConstructor0(Unknown Source)
	... 49 more
java.lang.RuntimeException: failed to evaluate: <unbound>=Class.new();
