Bug 1450 - When you change the theme, the Series Marks position and Title properties are incorrect.
Summary: When you change the theme, the Series Marks position and Title properties are...
: High normal
Reported: 2016-02-26 07:29 EST by sandra pazos
Modified: 2016-03-08 06:02 EST (History)
BubbleCould Series (54.70 KB, image/png)
2016-02-26 07:29 EST, sandra pazos
Description sandra pazos 2016-02-26 07:29:08 EST
Created attachment 557 [details]
BubbleCould Series
When you change the theme, the Series Marks position and Title properties are incorrect.  Follow the steps below to show the problem:
1- Add new chart with a series, for example, Line series.
2- Go to the theme tab and change the Theme.
3- Click Apply.
4- Go to the Chart->Series tab
You can see the Title series is changed to bar1. Also, in the Line series case, the Marks visible property is set true.
Also, I attached an image to check the problems.
